TTS Mastertune Information
Old 10-21-2013, 07:46 AM
BearShit's Avatar
BearShit
BearShit is offline
Smile
Originally Posted by bakes68
Bearshit im having the same problem with egr analysis, tried on a older version of software and worked fine, may be in the upgraded software.
Originally Posted by Mr. Wizard
Those files are too small, way too small. Something isn't right. I had J1850 data up in the 30,000 plus within the dongle. After importing the dongle files into the computer they were much, much smaller. So, are you talking about dongle files or imported data files?
I found the EGR error today and sent a note to TTS to review the software code settings. This has to be a software bug.
830958 on dongle 8777 /0 756kb imported
  #4372
Old 10-21-2013, 03:00 PM
Jenady's Avatar
Jenady
Jenady is offline
My experience with Mastertune is watching Mr. Wizard do his thing remotely on my pc. Now I am trying to read and learn how to do it myself. It just seems right.
I followed the instructions in Dave's "Hints" document and the manual. After all the setup I took a ride and created a new file with Flight Recorder. When I attempted to generate tune in Datamaster I got this:
I did run the Updater and TTS HD006.
I am guessing I failed to follow an instruction somewhere. Any ideas?
Thanks.
  #4373
Old 10-21-2013, 07:15 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Thanks.
Yup...
You didn't flash the VTune cal into your bike before tuning. Then you used a different cal to generate a new Vtune cal.. such as/and or
What is in your bike is a 009 calibration Vtune file. What you tried to generate in VTune was a 044 calibration. Mix match OS.
  #4374
Old 10-21-2013, 09:18 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
If you guys want to view this attempt at a TTS for Dummies here it is.
May help some. Most of you are far beyond this point. So this link doesn't vanish you can find the link in my signature.
https://app.box.com/s/5ls2mtfhjc8ybcx15f2y
  #4375
Old 10-22-2013, 03:02 AM
converted103's Avatar
converted103
converted103 is offline
Thumbs up TTS for Dummies
Thanks Wizard !!! This should go a long way to helping all that are lost in TTS/EFI Cyberspace with no map to home and trying to make a deal with the devil to get there!!!
Thanks and take care. Kev
  #4376
Old 10-22-2013, 04:03 AM
Sparra's Avatar
Sparra
Sparra is offline
Hi fella's...I have read lately that when you save your original cal to your computer it is also saved internally in the blue dongle...Is this only a recent thing???The reason I ask is that I bought the blue dongle just over 12 months ago and saved my original to my computer but it crashed and I lost it...Going by what I have read it should be somewhere in the dongle as well...Is this right and if so can I retrieve it???
Hope this makes sense...
Cheers...Sparra
  #4377
Old 10-22-2013, 05:12 AM
bakes68's Avatar
bakes68
bakes68 is offline
5th Gear
Cheers...Sparra
From what i have read sparra its only been since the software upgrade which was about april, which saves your last cal and original mte onto the dongle, i plugged my dongle into computer and pressed load tuning file from interface which showed me the last cal i programmed into bike but not original,but i cant load my original file which is also on my computer, because its not a tuning file,maybe when plugged into bike as well and press restore ecm it may give you the option then to load original off interface, i am only learning on tts but i hope this helps you a bit.
Bakes
  #4378
Old 10-22-2013, 05:19 AM
bakes68's Avatar
bakes68
bakes68 is offline
5th Gear
Bakes
also sparra there are original files stored on tts website dont know if you can match your original file by the vin numbers but it may help if you don't have yours
http://www.mastertune.net/repositary.php
hope this helps mate.
  #4379
Old 10-22-2013, 10:20 AM
Dozer40's Avatar
Dozer40
Dozer40 is offline
Simply outstanding!
  #4380
Old 10-22-2013, 10:28 AM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Originally Posted by Dozer40
Simply outstanding!
Why aren't you in Australia helping to fight those fires??
Quick Reply: TTS Mastertune Information
