TTS Mastertune Information
#5462
#5463
#5464
I wish. Kids, the lack of overall time, and the anticipation of vtune 3. I did one vtune and changed timing bit more. Ve #'s really went down in the lower kpa with the 57 cams. Is it common for lower ve there with cams?
#5465
Yup... most of the time. You can play with EGR to bring it up if you have the patience.
#5466
I just put a FullSac DX kit on my 2014 Tri-Glide. I have Rush Big Louie mufflers, a DK A/C and TTS with the canned download for FullSac. I Followed Mr. Wizards TTS for dummies to do the download but reading the manuals from TTS is working my brain. When I get ready to do this I will have a lot of questions. I do have a laptop, my wife on the back and some steep long mountain grades to do some runs on. Tony
#5467
#5468
I'm having trouble getting the VEs in the 3000 – 4500rpm & 20 – 25% TP area, under maximum 127.5 VEs. I’ve raised the displacement setting in tuning constants 3 times which is now set @ 10% over original displacement. Should I keep raising the displacement to lower the VEs, or is there some other adjustment I can do.
Engine is a +0.010 120R which I assembled myself & installed in an’07 Deluxe.
#5469
Are we sure the motor is mechanically correct which may be causing high VE's?
Could you post a box.net of your camdata file and one vtunedata file and your last vtune.mt8?
#5470
You’re right, the 120R is a crazy engine, finding a starting calibration among the TTS collection was a headache. Got one from SC via a member on one of the Aussie forums.
Build has SE 58mm TB, S&S 625, 110 heads with chambers reduced to 87cc, ports cleaned up & 2.120” int. 1.65” ext. installed, 11.2:1 CR.
Engine runs like a dream when I Vtune & load the last two or three DM runs I do for the day into a running map. I have been doing ERG adjustments as I go, by the way.
Will get back to you with the data files, once I jog the memory cells into action, as I haven’t used my box net account for some time.
