TTS Mastertune Information
#5552
Subscribed,
Been reading, reading and reading, OMG!! Reading some more !!!,,, Thank you Wiz for all your help, past present & future. I sure appreciate your patience with me. You, Ultra Nutz & Lonewolf are a HUGE asset to this site and to us all! Remembering Wurk Truk, sure miss John.,,, Thank you all for sharing knowledge and experience. Finding selfless people who are willing to take time to do what you all do for folks you don't even know is truly a rare thing these days. I'm lurking in the background trying to learn here. About got the TTS for Dummies pdf memorized!! lol,,At home Friday night, studying Mastertune manual,,, it don't get no better than this!! hahaha,, Thank Yall!!!
Dwayne
Dwayne
#5553
Hey Hubby... I'm about to render TTS/D II
Suggestion... why don't you take your old data files and practice ghost tuning.
Ghost tuning is where you follow all the normal steps of tuning using the software but have no bike to tune. If you need a copy of all your old data files for the Ultra let me know.
#5554
[QUOTE=Mr. Wizard;13376970]Hey Hubby... I'm about to render TTS/D II
Ghost tuning is where you follow all the normal steps of tuning using the software but have no bike to tune. If you need a copy of all your old data files for the Ultra let me know.[/QUOTE.
Good idea Dave! I have all the files for the Ultra as far as I know. Lookin forward to TTS/D ll. I'm excited about getting started on the SERK!
#5555
Help!
Ok so this is my second round of Vtuning on my 09 streetbob.
I just installed a Kuryakyn Mach 2 intake and want to install their canned map and Vtune it to my bike.
Question: When I open their base canned map the AF table has many variations throughout the load and rpm range. I set all except 100% column to 14.6 as required to collect closed loop data.
After Vtuning when I set the AF table back to original some of the cells go back to where the canned map was but some don't. It makes me believe that the "original" cell values were not stored or saved as required.
Should I "Set to original" or set them back to where they came? Which is correct?
FYI you can download the canned map here and see for yourself. Its a MT7 map so IDK how thats different from the MT8s
http://www.kuryakyn.com/files/tts/20...C-Slip-Ons.MT7
#5558
only reason I asked (and I'm sure the others would too) is I want to see the changes in VE tables from this map to your current running map along with any other changes that may have taken place before I tell you which way to go with your MAP table. But rule of thumb would be to set back to the values that kuryakyn provided. I'm not sure who that guy is that does those Kury maps but he spends a LOT of time doing them. Wiz and I were both impressed seeing things within some of those maps especially the timing stuff.
#5559
Kury does a pretty good job on their timing but beware... it may or may not be for your bike. When tossing in anything other than a TTS library calibration take extra time to test and read/analyze recorded data before lighting up the rear tire.
One more thing... most of the Kury files are MT7. Try to convert them to MT8 files or you will get the pop up screen that says... "WTF are you doing?? This is an old file !!"
You can use the Copy All Tables in the MasterTune Menu and Past to a new MT8. It will tell you what can be and what tables are left short.
#5560
Thanks for the help.
