TTS Mastertune Information
  #6101
Old 05-24-2015, 12:09 PM
needmorebeer's Avatar
needmorebeer
needmorebeer is offline
4th Gear
Originally Posted by msocko3
Your going to need to run the cam analyzer and set the IVO, what your reading is the part for setting the IVC, this part needs a dyno to determine. If your friend didn't bump the compression for those cams, he's going to be a bit bummed on how soft the bottom end is going to be.
Thanks for the help. I didn't do any research on the 259e cams. Not sure he did much research on the cams either. I was looking at a set of s&s cams for him, but he was sold these by the dealer.
  #6102
Old 05-24-2015, 02:43 PM
msocko3's Avatar
msocko3
msocko3 is offline
Most dealers are you worst enemy, I've seen more screwed up builds and parts combinations come out of dealers.
  #6103
Old 05-24-2015, 05:27 PM
user 46092's Avatar
user 46092
user 46092 is offline
Default Need a new cable!
Hooked my laptop up to my bike and couldn't connect to the bike.
I uninstalled and updated the HD06 driver from Mastertune but that couldn't help, and while surfing to get a new FTDI driver from the link on the Mastertune web site, the driver loaded and recognized the cable and it appeared in the device manager. But then I moved the USB to serial cable a couple inches out of the way and the device disappeared from the device manager; hence a break somewhere in the cable.
So, nobody carries cables for anything other than a cell phone, an Apple iPhone, iPad, iPod, etc., or an HDMI cable anymore, so Amazon or Newegg is my fastest source for a replacement. Best Buy, Office Max/Depot, Staples, etc. has squat. Anybody have to replace this cable? What brand works as a replacement?
  #6104
Old 05-24-2015, 08:32 PM
2-Piece's Avatar
2-Piece
2-Piece is offline
Isn't it just a standard USB printer cable?
http://www.walmart.com/ip/Belkin-6-F...-Cable/4660735
  #6105
Old 05-25-2015, 12:24 AM
user 46092's Avatar
user 46092
No,
I have the older black module, not the new blue one.
But, thanks for trying to help.
  #6106
Old 05-25-2015, 08:25 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Belkin USB to Serial adapter works well but don't get a cheap cable. Buy cheap, buy it twice.
Amazon.com: Belkin USB-to-Serial Portable Adapter: Electronics Amazon.com: Belkin USB-to-Serial Portable Adapter: Electronics
  #6107
Old 05-25-2015, 02:50 PM
user 46092's Avatar
user 46092
The screw downs to secure the connection are both female and block the male to female connection- neither one has the screws.
  #6108
Old 05-31-2015, 07:15 AM
joee's Avatar
joee
joee is offline
Default ruse control not working
I had my bike tuned and the cruse will not come on now
it is a 2013 ultra
is there some ware in the TTS to reset it
the light come on when I turn the switch on and the light stays red it will not go green or come on when I try but on when driving
thanks
  #6109
Old 05-31-2015, 07:20 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
it is a 2013 ultra
thanks
pull your front brake lever and make sure the brake light comes on
push the rear brake lever and make sure the brake light comes on
  #6110
Old 05-31-2015, 09:01 AM
joee's Avatar
joee
joee is offline
yes the brake light comes on with hand and foot brake
Quick Reply: TTS Mastertune Information
