TTS Mastertune Information
Old 07-15-2015, 02:46 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Staying busy helps... staying too busy overloads me.
I'm in control of things right now and happy to assist. Just may not be Johnny-on-the-spot
  #6222
Old 07-15-2015, 02:51 PM
MLJMT's Avatar
MLJMT
MLJMT is offline
If it helps you that's fine, if not that's fine too. I don't expect miracles and appreciate the help when and only if it works for you.
  #6223
Old 07-16-2015, 03:12 PM
MLJMT's Avatar
MLJMT
MLJMT is offline
Thought I would check my plug wires, one was a little below spec. the other was just right at spec. so I replaced them. Of course the dealer won't stock the factory cheap wires only the SE fat wires so I installed them. After I flashed a new tune I checked my DTCs and up popped P0132 and P0152 high front and rear 02 sensor readings. They were current and historic. I deleted them and they came back when I checked them again after restarting. Unfortunately I wasn't checking them on every flash because the engine light never came on. Lesson learned.
After wasting all this time and abusing my engine etc. maybe a dyno tune is pretty reasonable after all...
  #6224
Old 07-16-2015, 03:21 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
When you flash a new calibration it erases all codes.
SE wires suck. You need plain jane stock wires and plugs.
If you are banging on your motor then you should reconsider how you tune. A Dyno will bang on your motor much more.
  #6225
Old 07-16-2015, 03:46 PM
MLJMT's Avatar
MLJMT
MLJMT is offline
Doing cam analyzer checked codes showed current and historic, must have been from starting after flash.
They may suck but at least they ohm out good, the old ones did not which left me no choice.
That may be the case
  #6226
Old 07-20-2015, 01:13 AM
user 46092's Avatar
user 46092
user 46092 is offline
Hang in there Mr. Wizard
  #6227
Old 08-02-2015, 07:34 PM
98Ultra's Avatar
98Ultra
98Ultra is offline
maybe it isn't all the nthe new computerew computer after all, this one is not working right either;
  #6228
Old 08-02-2015, 07:46 PM
98Ultra's Avatar
98Ultra
98Ultra is offline
[QUOTE=UltraNutZ;14148326]open up your existing MT8 file you previously tuned for your bike and copy all tables
open up file DAA044-01 and paste the tables you copied from your previous file to this file
save and flash that then go run a few vtune runs and y
i'm gonna kill windows 8.1 .kjbcg0
[]-indows
i wonder why i cANT PROGRAM MY NBIKE
i THINK i,M starting to understand, I hate windows 8.1.
Open old file and copy, open new file and paste, Easy enough. Next get ready for flight recorder, Change all cells except 100 kPa to .981 , by selecting the RPM in the AFR table which highlights all cells......... once they all are highlighted what do you click next??? I havent been able to change anything from here.
I think when I did it before I did each cell individually.Never did figure out how to do more than one.
Oh, I have my old laptop working with the bike, never got windows 8.1 to work with the dongle
  #6229
Old 08-02-2015, 08:05 PM
98Ultra's Avatar
98Ultra
98Ultra is offline
This computer is not much better than the new one the new one flys very good across the room. Should have checked the website on the old computer, not much difference.
Page continues to show loading even after hitting the X.
Back to the original question, how do you change the table after selecting all of the cells? How do you not select the 100 kPa cells? When pasting the tables from the oldcal file to the new MT9 file, What do you do about the incompatable? files Been so long fighting the computer I don't remember what it said now. I think it was the front and rear VE tables
  #6230
Old 08-03-2015, 02:36 PM
Kiwirob's Avatar
Kiwirob
Kiwirob is offline
Open your MT8 file, go to, edit > copy multiple tables > select all, click ok.
With the MT8 file still opened, go to, file > load tuning file, then, from the TTS “Big Twin” calibration list that appears, select the MT9 calibration that is the equivalent to your MT8 calibration.
With the MT9 file now open, go to, edit > paste multiple tables, then fill in the mismatched check boxes you want or click on select all, then click ok.
This is assuming you have all the latest TTS updates.
Hope this makes sense. - Rob
Quick Reply: TTS Mastertune Information
