TTS Mastertune Information
#6351
#6352
Don't believe you are doing anything wrong. These graphs are usually fairly common. With your set up though it seems to have pushed the IVO earlier than usual.
#6353
#6354
#6355
Knock Control System in your Tuning Constants not the table. When you disable Knock Control System you open up your motor to damage via preignition when tuning. It's a safety protocol.
#6357
Legacy FTDI VCP USB Driver for Windows XP/Vista/7/8
http://www.mastertune.net/downloads/...-Certified.exe
I use Win10 and have no driver issues with the USB. Can't be of any more help than that. You could contact TTS and inquire.
#6358
I found that the throttle response came back if I reverted all cells 0-30% and idle to 1500rpms to original values. Vtune had pulled a lot of fuel out those cells. After i added the fuel back on both VE tables the throttle response came back and not more stuttering and hesitation.
I pulled those trouble areas out of closed loop so Vtune don't bother them anymore.
#6359
The Legacy drivers are located on their website on their download page or here is the quick link to the drivers.
#6360
Got a small problem,
Can't get comms on my new ultra. Tried 2 different tuners without luck.
Both work on my fatboy. I checked the 6 pin plugs of both bikes. Fatboy has 6 pins Ultra have 5. Is this the problem? Missing a pin?
Would really appreciate it if someone with a ultra limited could take a look at their bike and verify if I do have a missing pin
Thanks in advance.
Dave
Thanks in advance.
Dave
