TTS Mastertune Information
#6431
#6432
#6433
The problem was with Win10 on my HP Elitebook.
#6435
Double post
Hello all..
Excuse my duplication of this question (I have asked in the SERT thread too)
My 2011 Road King has the primary engine crank sprocket reduced to 32T from the standard 34T and now my cruise control wont work.
I already have a SERTpro but am lead to believe that it is not capable of altering this setting.. (primary ratio).. I have not personally hooked it up, I am going by the local Harley mechanic close by.
Can anyone here confirm or deny if the SERT will do it? Will someone also confirm that this is definitely possible with the TTS tuner. (which I will have to fork out another $600 for.. poor Australian dollar vs American dollar)
#6436
Not only does your 6th gear light not work but your speed is off by about 4 km hr.
The SERT will not fix this. The TTS will but so will.
With a 2011 bike how is it that you have a SERT. Do you really mean the orange SE Pro tuner?
There is a cheaper way to fix the 6th gear light and speed. That's by using the Dakota Digital SIM-1
All you need to do is calibrate the speed sensor counting the 5th gear trans teeth. When you find the sweet spot your speed will be correct and your 6th gear light will work again.
#6437
Hello All,
2015 Roadglide only mods are a hi-flow air cleaner and Harley SE slip on exhaust. I have been running a TTS v-tuned improved canned map for some time now and the bike performs much to my satisfaction. Certainly better than the stage 1 Harley flash I was running previously. The issue I'm experiencing is a slight intermitted knock at idle. It seems to idle ok (1000 rpm) but every few seconds or so it stumbles with a knock. Only does this after it is well warmed up and seems to be worst when it is very hot. I always use 91oct gas. Could this be a timing issue? Thoughts or recommendations appreciated.
I noticed the issue is more prevalent the hotter the ambient temperature is. I'm probably way off base and not sure if adjustment in the IAC Spark Correction table can be made at idle or if that would even help anything?
#6438
#6439
Well Mr Wizard, per your suggestion, I went out this evening to record some data to analyze but I cant get the interface to connect. All worked perfectly 3 months ago which was the last time I had it hooked up but tonight, all I get is a "interface not detected" message. Not sure if it is my blue dongle interface, a cord, or the software. My office is just down the road from TTS so I figure I will take the dongle & cords over to them tomorrow to be checked out. Let me know if you have any suggestions to my current connection problem. In the meantime though, thanks for replying to my post and I'll get that data downloaded just as soon as I can. Thanks again.
#6440
