TTS Mastertune Information
#6711
#6712
#6713
#6715
I use to use a rubber band and it worked well. Lay the rubber band down on the table flat, then take you cord and lay it across the rubber band. Take each side of the rubber band up into the air and then slide one side through the middle of the other. This will tie the rubber band around the cable. Now take cable and plug it into the laptop and stretch the open loop of the rubber band around the laptop to pull the cable in the USB slot.
#6716
Thanks UltraNutZ,
The engine is untouched (2009 Dyna), the only changes are an aluminum air filter housing with the oval K&N Road King element, and the SPF two into one step pipe.
The selections in the "TTS Delphi Cal Listing" cover a lot of bikes, but in the 176 Dyna listings the cal closest to my configuration is the CAE176-03 MT9, the exhaust is not a match, this cal lists the exhaust as a shorty, but it reflects a stock engine (Note: I screwed up the cal number in my previous post, it should be CAE176-03 not -04, I will edit that).
Best Wishes: Mike
Best Wishes: Mike
#6717
Thanks ultra for the input. My Indys dyno is stingy. I put it in the road the other day and man it pulls!! Last cams I'll need in this bike. Wish I could've gotten 110/90. But I'm thrilled with how it's running. I might eventually run tts autopilot and Vtune to see if it will improve anything....might even take it to another dyno in the future but I'm satisfied with the cams...glad I got em.
#6718
#6719
I want to thank everyone who helped and got me straightened out on how to use the tts. Thanks fellas
After 9 vtune runs this is where im at.Bike runs great
Sometimes when I'm shifting from
2-3
3-4
4-5 between 2500 3500 rpm I get a slight pop out the pipes
let me know what you think
https://app.box.com/s/obicrc9xgsm8bk9zn4y8w4v0nabgroj9
If I did the drop box right
2-3
3-4
#6720
For those of you who don't want TTS to search through all of your calibrations everytime you open up Master Tune. You can turn it off by going under set up/ options and uncheck "Use File Search Dialog."
For most this wont be a big deal. But tuners that have 6000-7000 files on your computer. It takes time, everytime.
On the other side. This feature will allow you to put in info about your bike and will give you a suggested starting cal.
HTH's
HTH's
