thundermax issue for newbie
Hi guys... I installed my thundermax, pipes, air, got it up and running, lowered down my rpm to about 720 in 100 rpm increments, took it for a couple hundred km today, and it ran great. At the end of the ride, however, the idle doesn't come back down, when I am shifting, rolling off on the throttle, and even coming to a stop.
Now, I think (know) I made a few hasty mistakes when installing the map and getting the module all sorted, my question is, can I just erase the info off the module, start over from scratch from step one with the original map, and this time pay a bit more attention?
Also, I noticed on a thundermax help site a specific "IAC Auto" button next to "Link". My software doesn't have this. After reading the manual, I am still not clear how to auto adjust the IAC (this could be the issue with my high idle... again, hasty install and not paying attention).
Any info if I can
A. erase current map and start over, and
B. how to set the IAC stops,
would be greatly appreciated.
Thanks guys
Any info if I can
Thanks guys
First off, go online and update to latest sofware and update to latest firmware 4.8 .It will have all the newest features you want. Update the module to latest firmware first. Link up and read module map and settings. Go configure, firmware update, choose the latest version and follow the onscreen directions. When this is done go into basic settings and change the idle back to no lower than 940 rpm. Write module map and settings back to module. Unlink with button and initialize unit. Click the link button again and read module maps and settings. Click on iac auto, in map editing, which will remove existing iac points anyway and when screen shows it's ready start engine and when the engine hits 270 the iac will automatically shut off and you are done. Have the temp gauge displayed and the monitor button beside the link button activated before starting engine. Do not touch throttle from start to finish. Click to unlink from module and shut engine off. Disconnect the cable. When you close the software it will ask to save map. That's up to you and not really important at this stage. You can always save the one you have now that's been tuned at any later time you wish.
Ron
Ron
oh man
Found this in an on-line manual.. My bike is a 2008, so does this mean I don't have to try to figure out this funcion??
This feature is ideal when using the ThunderMax ECM on Gen I H-D two piece throttle
bodies, (Year 2001-2005 models) and aftermarket throttle body or custom engine
applications where the base map does not match the components on the engine.
Most installations performed with H-D Gen II one piece casting throttle body (2006-2009) do not require this function for proper installation.
If you want to use IAC-Auto on a late model (2006 – 2009) motorcycle, go right ahead. Although it may be unnecessary, it will not harm anything to use the function.
From the manual...
I'd clear all the offsets...start from the beginning with a cold engine, load the map fresh, initialize do the warmup procedure and ride. Don't change anything until you've logged a few miles on it.
"If you want to use IAC-Auto on a late
not harm anything to use the function."model (2006 – 2009) motorcycle, go right ahead. Although it may be unnecessary, it will
Ron
