One more code ?....P0374 CKP Sensor Synch Error EFI
This code shows up now on the trouble code. I did some checking and it means
CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the ECM
where it is used to reference engine position (TDC) and speed.
Again this is on a 2005 HD Ultra, fuelpak, ness big sucker and res-tec hardkrome pipes.
Thanks again for any help to fix this, or is this a shop fix? I am mildly mechanically inclined so the simpler the better.
It shouldn't be hard to replace. It's the little round thing sticking out of the front of the crankcase by the oil filter. About as big around as a dime with one bolt holding it and the wires in a protective case.
PS: Remember to lube the o ring on the new connector with clean engine oil before installing it.
