fuelpak, Ridemaxx, or Cobra Fi2000
I've had the Tmax in my bike. It is tuned with the SEST now. I've used the TTS on four friends bikes. It is hands down the most capable on the market. I have the HQ's Protuner in my bike. It looks after the fuel and I adjust the timing with the SEST. The TTS allows you tune your bike with out the need for external devices or a trip to the dyno. The TTS adjusts your timing with RPM vs Map. It also allows you to adjust it with Temp vs Map. Even the heat management with the TTS cycles both cylinders not just the rear. You can also record 6 different kinds of data.
