Start switch won't work - Harley Davidson Forums
P
Thread Tools Search this Thread
Old 10-20-2009, 07:39 AM
flyboy5584 flyboy5584 is offline
New Member
Default Start switch won't work
Help!!
I recently installed a set of mini apes on my 06 SG. I added the 12" wire extensions after I ran the wires thru the bars. Now that they are installed, everything works as advertised from the right hand controls with the exception of the start switch actually initiating the starter. No solenoid clicking, no nothing. The turn signal works, all radio controls work and the Off/Run switch appears to work.
When attaching the negative cable back to the battery after the install was complete, there was a small spark. Due to the spark, I have looked at all fuses, including the Maxi fuse, actually replaced the ign and start 15amp, swapped the 2 relays under the seat (not sure which one is the starter relay, but both are the same), and checked the resistance on the start wire thru the bars. The start switch and Off/Run switch were working before I started the install and assume they are still working now.
Before I go thru the trouble of pulling the bars to remove the wire bundle in order to run each individual wire, is there anything else I am missing? Is there a hidden Circuit Breaker or another fuse not in the fuse block I am unaware of? Should I think of the coincidental failure of the start switch?
Any help would be appreciated.
Thanks,
Jerry
P
Thread Thread Starter Forum Replies Last Post
Unedited: Adding a second relay to fix the dreaded click D1gger Evo Classic Models 210 06-09-2016 03:35 PM
Electrical problem. Keep blowing fuel pump fuse stal94gt Ignition/Tuner/ECM/Fuel Injection 27 03-19-2016 06:10 PM
No power to fuel pump fuse Jason Anderson Ignition/Tuner/ECM/Fuel Injection 3 02-06-2016 02:13 PM
Need major HELP PLEASE **NO START** capt dcg Touring Models 7 07-09-2014 02:59 PM
Led accent lighting trouble Scooter68 Softail Models 14 04-06-2014 11:20 AM
Tags
controls, harley, start, starter, switch, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
