U1097 Loss of Speedometer Serial Data. What does it mean?
Absent the check engine light coming on for about 5 seconds after startup, I can't find anything else wrong. I checked all my fuses yesterday and some of them were a tad corroded. I cleaned everything up and cleared the code but when I started the bike it still did the same thing. Still stumped.
How did you "Clear the code"..... 'Cause you can't do it through the speedometer....
That is an historic code... something you did triggered it, like disconnecting the ECM, TSSM, Speedo/Tach while the maxi-fuse or battery were plugged in, or you have a loose cable...
I did #8 in the following link
https://www.hdforums.com/forum/sport...odes-dtcs.html
code, data, davidson, electrical, explained, fuses, harley, harleydavidson, hd, ignition, link, loss, serial, speedometer, u1097
