Installed Fuelpak and now have Alarm issues
Hello everyone, first time poster here but I've done significant research on this since it happened today. I'll run it down:
2009 HD Fatbob about 2950 miles. I'm the 2nd owner and the original owner only put 146 miles on it.
1. Installed V&H 2-into-2 Big Radius
2. Installed V&H Fuelpak
https://www.hdforums.com/forum/engin...ssignment.html
http://www.hdtalking.com/alarms_and_...procedure.html
http://www.hdtalking.com/alarms_and_...both_fobs.html
I did not fully complete this though:
https://www.hdforums.com/forum/engin...roceedure.html
I have not been able to pull up the "current PIN." When I do the sequence thats supposed to show me it, the Odometer just comes up with 0----. And I tried to input the PIN the dealer told me they use during setup and it didn't work. I am able to disarm the alarm and physically start the bike, but its really hit and miss, I cant get it everytime.
Any other suggestions? Thanks so much
- Disconnected factory harness from ECU
- While not instructed to do so, I disconnected the negative lead from the battery. I did this just to be safe since I needed to force some wires around the tight area
- Continued with remainder of installation and plugged Fuelpak connector to ECU and then re-connected the negative lead.
- I input all the correct values for my setup
