Blown fuse for lights
Old 08-01-2006, 04:29 PM
wvrider's Avatar
wvrider
wvrider is offline
Default Blown fuse for lights
I added the brake light kit (Harley kit) that makes the turn signals in the rear brake lights also. Everything was good for a day then the fuse blew. It states in the instructions that it will pull an additional 4 amps with this kit, but it doesn't say to install a higher amp fuse. Has anyone done this and increased the fuse amperage by 5 amps? I don't want to toast the circuit. Any thoughts?
Also had blown P&A fuse. What is P&A????
Old 08-01-2006, 04:52 PM
rh8234's Avatar
rh8234
rh8234 is offline
Default RE: Blown fuse for lights
What is the amperage of the fuse and what is the total draw on the curcuit? If total draw on the circuit is below fuse rating, look for a short somewhere where you were recently working.
Old 08-01-2006, 07:48 PM
wvrider's Avatar
wvrider
wvrider is offline
I haven't checked for draw yet, just blew the fuse on the way to work today. As for a short, module simply plugs into harness under seat, no wiring needed. I pulled the seat to make sure nothing was pinched, everything was ok.
Old 08-02-2006, 09:37 AM
rh8234's Avatar
rh8234
rh8234 is offline
I'd check to see what the draw is. I don't think it would be a good idea to stick in a higher amp fuse because the fuse size used is based on the guage of wire on the circuit. If you up the fuse by 5 amps, you might end up setting fire to wires before the fuse blows if you ever get a short.
matt1234
06-23-2012 05:14 AM
Andjh123
11-30-2009 10:17 PM
SilverEagle
10-30-2008 02:36 PM
seegs
08-07-2008 12:34 AM
Hoopman
04-01-2006 09:52 PM
Quick Reply: Blown fuse for lights
