Open Loop vs Closed Loop
Old 06-06-2010, 10:24 PM
iclick's Avatar
iclick
iclick is offline
Originally Posted by Pine Tree
I don't understand that statement at all.
Just about anyone can get a fueling system to dump so much gas into an engine at cruise to make those following close behind puke from the smell of an overly rich mixture...not to mention poor gas mileage too.
The range of accuracy for NB O2 sensors is .400v to .800v, which translates into 14.2-15.0:1 AFR. Once the fuel ratio is outside these limits, the accuracy of measurement rapidly deteriorates. This is why NB sensors are most-often used as a 14.7:1 AFR voltage switch.
Old 06-06-2010, 10:27 PM
iclick's Avatar
iclick
iclick is offline
Originally Posted by ColdCase
The XiED works great for cooling a motor a bit (fattens up the mix across the board). I ran them for months. But I wanted to get rid of an annoying surge and decel pop, which the XiED did nothing for. Its worth only a few points A/F WOT but sometimes that is all you need.
How can xIED affect WOT when the stock O2 sensor ceases to work after about 50% TP? It is well-beyond its functional range by the time it gets to WOT.
car5car
11
10-23-2009 04:57 PM
Touring Tom
05-12-2009 10:10 AM
cbass68
General Topics/Tech Tips
11-16-2008 07:03 AM
wdcamp
03-25-2008 08:36 PM
txtec
12-22-2007 10:50 AM
Quick Reply: Open Loop vs Closed Loop
