Need recomendation on fuel controllers
Have an 07 Fatboy (with CA smog). Installed SE stage one air and V&H Straight Shots. Ive been trying to figure out what the best (dependable) fuel controller to install. The bike runs ok now, with little popping but I think it is running hotter and using gas. I was looking at the Daytona Twin Tec, Auto tune with O2 interface but seems it has only been out for a short while. I see Thundermax seems to be out there too.. Anyone have experience with these or reason to recommend something else?
Also want to know if it's an easy install for a backyard mechanic or should I take it in? Would sure appreciate your input.
Steelguy
Steelguy
Steelguy
Steelguy
Why does a systems that uses wideband sensors not provide better street performance? Sound illogical. But these companies are stretching the truth (marketing) a bit by advertising wideband sensors where, in fact, they are broadband type. Narrowband and broadband sensors use the same technology, they compare exhaust gas vs gas that comes in via the wire to come up with a voltage that corresponds to relative O2 levels. Broadbands add an ion pump to broaden their measurement range. In order to use them effectively, the sensor controller needs to know the pressure difference between inside the exhaust pipe and outside which none of these consumer systems do. So in the end the sensors perform about the same within the narrowband range but are not that accurate outside the range. True wideband sensors do not have this problem, but they also cost roughly $900 each.
Bottom line all these systems provide a great running bike, the TTS with less money and hassle.
Modified? There's a recent thread in the Touring section of this forum where a highly modified supercharged bike was tuned with both TTS and a PCV-AT. TTS was used to provide the base-map tuning, but the PCV-AT had to be used because TTS couldn't handle the boost pressures needed for the job. To suggest that one tuner is better for modified bikes is not based on any evidence you can provide. Let's be honest, shall we? TTS is a fine system, but there are other fine systems on the market, and which is better depends on which feature set the rider prefers.
It costs less money than either the PCV autotune or TMax and does not require any mechanical skill to install. You tune for economy, power or both.
...First, you can't tune in closed-loop mode past 50% TP, and within closed-loop mode you can't tune beyond 14.2-15.0:1 AFR. Second, you can't tune in open-loop mode without a dyno-tune, at least not without guessing. If you say you can, explain in detail how you can tune in open-loop mode without feedback? When you factor in the dyno-tune, which is not required to tune AFRs with either PCV-AT or TMax, the TTS kits is more expensive...
Dyno machines were around LONG before the use of fuel injection and closed/open loop operations. Closed/open loop is simply a part of the overall tuning of a motor. And the O2 sensors are nothing more then another tool that's available to those that wish to use them (hint...some systems advertised here actually require the sensors be disconnected).
Tuning has been going on since the first internal combustion engine was invented. And they did the tuning without the aid of scopes, computers, and dyno machines.
So, yes, one can tune in open loop with or without a dyno.
Sorry my friend, either you weren't exposed to points, condensers, timing lights, and vacuum gauges or you've forgotten the foundation of today's tuning.
Remember what I was responding to. Coldcase always enters these tuner discussions with grandiose claims that his tuner of choice (TTS) is the "best" tuner on the market, with no caveats, conditions, or allowances for individual feature preferences. I would simply like to have him present the reasons why he thinks so, but in previous threads this never happens. He will pop-up in future threads, often hijacking threads that don't pertain to TTS at all, with the same claims--only to start the cycle over again.
Now, what are the pieces I am omitting in this discussion? Rather than make vague accusations, get specific and let's discuss it. Let's start with the part of my message above that you don't understand and the points you feel have been left out. Please be specific and we'll discuss each in turn in a rational way. You didn't mention even one in your last message and I have no idea what you're referring to.
Accusations: a noun in the plural form, a charge of wrongdoing.
Are you sure you wanted to use that word? I did express an opinion (an appraisal formed in the mind about a particular matter) but did not charge you with a wrongdoing.
Details? I'm well aware of your fondness for that term. I might have been born at night but it wasn't last night.
AMF! (detail - that means adios my friend)
