Brake light not firing - 07 Night Train
Old 05-07-2010, 02:54 PM
IGOTTASRT8's Avatar
IGOTTASRT8
IGOTTASRT8 is offline
Default Brake light not firing - 07 Night Train
Running lights work, brake light does not. Replaced the bulb, no dice. All stock bulbs and stock switches. Any clue?
edit: Both the front brake lever and the rear brake pedal will not fire the brake light.
EDIT: If you need a new switch don't go to the dealership ($60). Get it from Dennis Kirk ($16.95)
http://www.denniskirk.com/jsp/produc...mmyId=#fitment
Old 05-07-2010, 02:59 PM
BoomerBob's Avatar
BoomerBob
BoomerBob is offline
Have you checked both the hand brake and foot brake? If one works and the other doesn't it has to be a switch. If they both don't work I'd suspect a wire under the fender but it could be anywhere in the brake electrical system.
Old 05-07-2010, 03:30 PM
IGOTTASRT8's Avatar
IGOTTASRT8
Old 05-12-2010, 11:34 AM
IGOTTASRT8's Avatar
IGOTTASRT8
I checked under the fender and it looks like all the wires are in tact.
Is there a unique fuse for just the brake lights? I thought there was just one fuse for the headlight, tail light and brake lights.
Old 05-12-2010, 09:45 PM
BoomerBob's Avatar
BoomerBob
Your fuses are under the rectangular cover under the seat by the battery. Check all the fuses.
A service manual is an excellent investment and will pay for itself the first time you use it.
Old 05-15-2010, 09:17 PM
IGOTTASRT8's Avatar
IGOTTASRT8
There is only one fuse for the lights. It turns out the problem was the switch on the handlebar. $60 for that thing... give me a break.
Old 05-17-2010, 10:51 AM
IGOTTASRT8's Avatar
IGOTTASRT8
Ok, now the brake light is always on, lol. It seems that the brake lever will always be in contact with the switch unless I physically press it away from the handlebar. What did we do wrong?
mrush1130
09-22-2013 10:08 AM
ceekncabin1
05-04-2013 09:52 PM
BigLowRider
06-24-2009 06:36 PM
sliceball
Electrical/Lighting/Alarm
03-02-2009 12:43 PM
Skip
08-12-2006 01:48 PM
Quick Reply: Brake light not firing - 07 Night Train
