73 Ironhead Starter Problems
whats up everyone ?
Im having some problems with an old Ironhead sportster, I just replaced the Starter motor and solenoid after having problems with it not starting. The battery is fully charged, and it started right up no problems, next thing I knew the bike missed a couple times and stalled out. I hit the start button and it just kept cranking and cranking, so i took out the key, and then shorted the solenoid and removed the lead to the starter and disconected the battery. Im trying to see if anyone might know what the problem is ?? Im going to pull the start button apart on the hand control and see if something is wrong there, but im open to suggestions. any help would be greatly appreciated.
thanks.
Len.
thanks.
Len.
Received 19,349 Likes
RE: 73 Ironhead Starter Problems
I had one of those (AMF 1000cc XLCH) Gave me fits until I looked at the points, the spark advance was frozen open. I pulled the points plate off and the grease had hardened from the heat. I cleaned it all off and put some nice high temp grease on the centrifical advance posts and all was well. I cooked two solenoids before I discovered what was wrong. One other thing mine did was once in a while the spark plugs would not fire under compression, pull them out and they would fire, put them in and would not do crap. Put a new set in and it would run just fine. Try a new set of plugs and check your points and spart advance. Hope this helps.
-Scottie
-Scottie
Thanks for the response, Im going to check the points tommorow before I go to the bike shop to get another solenoid, the new one I just got is toast from the non-stop crank episode ... I did install the starter relay and tried to start it up and no action, removed the solenoid and its all done ... So tommorow im going for a new battery, battery cables, solenoid, and hopefully the ignition is ok ... Thanks for the help
well now i have a new battery, new starter, new relay, solenoid, battery cables and when i try to start it all i get is a click/clunk from the solenoid. when i hook a jumper from + to starter the starter spins freely. when i bypass the solenoid all i get is a clunk. battery reads 12.78 volts. engine can turn over by hand with the plugs out. I have the primary cover off and when i hit the button the gear only sometimes engages with the clutch gear. it seems like it does not want to return fully. I also pulled the solenoid apart to check the contacts and they still look pretty good. one small pit on one of the contacts, and a few on the washer, but i lightly sanded them down and they look good.
Please help me out with any ideas, its driving me nuts. Thanks alot ! I also performed all the continuity tests on the starter, and all is good. and all the cables are clean, new and tight. I really could use some advice. should i take the batter in to get load tested even though it is new ? let me know what you think should be my next steps. Thanks again.
Len.
Len.
Just to close the case for the record, the problem was a broken roll-pin on the solenoid plunger alowing one of the springs to be unsprung, getting the plunger caught up not allowing full contact inside the solenoid to get power to the starter and to get the drive gear properly engaged. now its back in action !
1abrat
Electrical/Lighting/Alarm
11-12-2016 07:11 AM
