I thought my circuit breaker issue was resolved...
Old 06-14-2010, 12:24 AM
kkiley's Avatar
kkiley
kkiley is online now
Default I thought my circuit breaker issue was resolved...
2000 Fatboy carb keeps kicking the master circuit breaker. It has a new crank position sensor and battery. Hooked up a VOM and the charging system is working correctly. New 30 amp circuit breaker installed. Cleaned the ignition switch. I literally had the whole wiring harness unhooked, pulled out, checked for shorts and any bare or crossed wires. Didn't find any issues and put it all back together carefully. Rode it Thurs, Friday and all day Sat with no issues. Stopped for a BD party and went to ride home after it sitting for 5 hours. Got about 5 blocks and it cut out. Turn the ignition switch off and on and it starts right back up.
It was very hot all day Sat and no issues. It was cool and dark when it died. I must be looking for a voltage spike that's kicking the breaker. I've had the VOM hooked up when it quit and it was registering 14.19 volts at the battery.
I'm thinking the starter relay, neutral switch or bank angle sensor. It's doing it just enough to PMO but not bad enough to duplicate.
Any thoughts would be deeply appreciated.
Kettenhund75
02-17-2021 02:38 PM
Hrlyric
08-02-2013 05:21 PM
popcorn13
11-12-2012 05:04 PM
M&P340
04-29-2012 05:55 PM
81fxb
08-06-2008 05:16 PM
Quick Reply: I thought my circuit breaker issue was resolved...
