6th gear light and red security light come on while coasting
Hi Folks. Hope you can help me diagnose this problem. I have an '08 Ultra Classic. While on a ride this weekend, I was coasting down a mountain road with the clutch lever pulled in. Nice and quiet, enjoying the scenery. But after about 1/4 mile, both the 6th gear light and the red security "key" light came on. They both disappeared once I let the clutch out and applied a little throttle.
At the next stop, when I powered her up again, the red security light stayed on longer than normal, about 8 seconds or so, then turned off. Every other startup since has been normal.
Do you have any ideas what caused the two lights to come on during coasting? Is this something I should worry about? My wife and I are about to go for a week-long trip, and I don't want to get stuck in the boonies....
Thanks in advance..
Thanks in advance..
DTCs B1154, B1155 may occur if the vehicle is ridden with
clutch disengaged (pulled in) at speeds greater than 10
MPH (16 km/h) for more than 60 seconds (coasting down a
long mountain road).
Straight from the 2008 EDM so you now have a historic code.
It will clear itself eventually or you can use the speedo to clear it.
After letting the bike cool down again and pushing the vent back into the lower all was fine. I tightened it up when I got home and it never happened again.
Never happened on any of my other bikes up to 07 so checked the manuals and sure enough nothing to worry about.
It has never affected any of my bikes in anyway.........YMMV
