Late Model Ignition Question..
I was hoping one of the experts could answer a question for me about the ignition on a late model (2009) Dyna "96" inch stock engine.
Since this engine has "Single Fire" ignition and also does Not have a Cam sensor, how does the ignition know the difference between TDC of the compression stroke and TDC of valve overlap.
Each 360 degrees of revolution of the crank looks exactly the same electrically to the ECM. Therefore how does the ignition system know NOT to fire on valve overlap and at the same time to know to fire on the compression stroke.?
Thanks!
Thanks!
In years past, a cam position sensor told the the ecm which TDC was compression and which TDC was valve overlap. And when we had dual fire coils it did not matter because each plug was fired twice for each complete cycle. The plug fired on TDC of exhaust (overlap) and it also fired on compression.
Now with late model bike, they are single fire and they have no cam sensor... That's why I asked because this really has me puzzled.
Tks Lonewolf, The Crane ignition systems work that way and I was wondering if the stock Delphi did the same thing. That is a pretty trick way to phase the ignition system system to the crankshaft. It almost sounds like it would work only in theory but I guess it does work in practice because I see no other way to do it without a cam sensor or dual fire ignition.
According to Crane, their system only phases during cranking and not while the engine is running so it appears to me if the system looses sync for some reason, you have to restart the bike to sync/phase once again. Of course if you happen to loose 2 (or any even #) of sync pulses you are really back in sync or phase once again. Any odd order of sync misfires will be the kiss of death.
It amazes me that within all the Harley service manuals I have read, there is NO mention of it anywhere. It must be one of their "secrets"..
Tks again!
kathygill12
07-20-2010 11:08 PM
toolbox
Custom Models
09-29-2006 12:17 AM
