mechanical to electronic speedometer conversion
Old 12-18-2010, 04:46 PM
nomad57's Avatar
nomad57
nomad57 is offline
Stage II
Default mechanical to electronic speedometer conversion
Hello, I have a 74 fl that has a baker 6sp (has provision for the sensor) with a thunderhart micro harness and would like to use a later model harley electronic speedo possibly the model with the built in tach. If anyone could help I would appreciate it.
Charles
Old 12-19-2010, 12:25 AM
Teflon Tom's Avatar
Teflon Tom
Teflon Tom is offline
Thumbs up I did that on my 94 FLH
I had to drill my case but if yours already has the holes for the sensor your more then 3/4 the way there. You can use any electronic speedo up to an 04, the 04 and up use a data line from the ecm. Write Thunderheart for the speedo hook up they are a #1 firm for information and products.
I just hooked the wiring up using an 03 FLH wiring diagram cause I used an 03 speedo it worked great.
NickSchoff
EVO
09-19-2023 11:39 AM
jreichart
12-24-2012 08:42 PM
fatboyopen
12-09-2012 07:06 AM
cradar69
Screamin Eagle CVO Models
06-21-2007 02:10 AM
philinms
05-31-2007 11:17 PM
Quick Reply: mechanical to electronic speedometer conversion
