SEPro/SEStreet Tuner Information Thread
#2981
Trying to set baseline before starting Smart Tune.
I pulled the file from my VCI, and in Tuning Setup (Working) it's set for 107.3 CID. (Stage 1 file 044AAO003, original setting is 103.3).
Any ideas why a dealer would set it like that, and how that affects tune if the engine is actually 103?
More information about the bike, in case it's needed:
2012 SG, 103 with performance air cleaner and V&H Monster Rounds. Bike was purchased at just over a year old, with 300 miles on it (personal sale). It's got a few thousand now, with no issues that I'm aware of. Runs and rides fine, no hesitation or decel popping.
I called the dealership where the bike was purchased, but they didn't have specific records. Purchase invoice shows all the parts but no dyno tune, so assuming this was a somewhat generic flash.
#2982
If the tuner ran out of adjustment on the VE tables he would raise the C.I.D. to allow more room to adjust. Take a look at your VE tables both front and rear and see if there are any cells up around 120. If there are then that's your answer. It's not uncommon to have to do this.
#2983
Peg20, thank you for your reply. See below.
I'm thinking the same, based on the screwy Air-Fuel Ratios (see attached pic)
I think that's my plan. This actually is that canned tune, with only the 3 mods mentioned.
The Air-Fuel Ratios were lowered out of closed loop mode (see pic), so I don't believe the O2 sensors are able to correct anything.
I have a stock (with cat) headpipe and V&H slip-ons, so I'm hoping reversion is a non-issue.
That's my concern.
I've been getting about 40mpg, and the plugs looked fine when I changed them during the 1k service. So, not a train wreck, but definitely room for improvement (look at the 85 column in the pic - it's leaned out all the way for some reason!).
That's my concern.
#2984
Then I would assume that they just raised the CID to add fuel globally to the whole MAP. Any way you can e-mail me your MAP, i'll look at it and see what all they did to it? PM me your e-mail if interested.
#2985
#2986
Do not install the modified calibrations on any model other than those specified in this User’s Manual. Doing so may result in poor engine performance, electrical-system damage, and/or engine damage.
I found this in the warnings and disclaimers as I was looking through the updated software. I currently run a map for a later model bike so I can smart tune and run some closed loop. Does anyone know if this is actually a problem, or have they just put that in to cover themselves?
Thanks, Matt.
Thanks, Matt.
#2989
#2990
SEPST Download
Awesome thread,
I have a 2009 SE Pro Super Tuner (32109-08A) installed by dealer in '2010. Haven't had the need to do updates or tuning. I've installed 2 into 1 exhaust. Time to update & Tune. Problem is; The H-D down load wont accept my VIC # so no down load.
Where can I get the software download ?
Thanks for the help.
