SEPro/SEStreet Tuner Information Thread
#2991
Awesome thread,
I have a 2009 SE Pro Super Tuner (32109-08A) installed by dealer in '2010. Haven't had the need to do updates or tuning. I've installed 2 into 1 exhaust. Time to update & Tune. Problem is; The H-D down load wont accept my VIC # so no down load.
Where can I get the software download ?
Thanks for the help.
#2992
#2993
#2994
base maps
I've read many pages in this thread and cant find any site to download base maps that might come with a SEPST. When I bought my tuner from HD dealer They installed it . I didn't receive any software etc. Jim helped me get the software downloaded but I need the base maps to start with...
When I do the 1st hook up to the bike will the existing map get pulled from the cycle? Where can I find the other base maps?
This is such a worthwhile thread. Thanks to all !
#2995
#2996
Adjusting for Gas?
It took me about 4 days, but I managed to read the whole thread, whew!
Today I replaced the stock pipes and air cleaner with a Big Radius 2-2, Arlen Ness air cleaner, and Monster Baffles on my 14 Fat Boy.
I also flashed the ECU with the Stage 1 Map.
In northern VA I can't find any pure gas stations, so do you recommend adjusting any setting in the calibration for the gas that is sold in my area, or is using E10 93 octane with smart tune runs just fine with no adjustments?
One other question. Are there any negative affects running smart tune with the weather being 40-50ish degrees knowing summer will be here later?
Thanks,
Chris
Thanks,
Chris
#2997
Base maps are part of the software. In the tuning page (tuning fork) towards the top it says something like tuning calibrations, that should bring up the base maps and the tab to 'manually select file' if you have other maps on your computer
Sent from my iPhone using IB AutoGroup
#2998
Question.....
I do apologize if this has been asked, but with 300 pages (I quit after the first 100). It seems this post has a wealth of knowledgeable people!
I just installed a stock header from an FLHX with dual pipes with the cat removed, stock slash cut mufflers that have been gutted and refitted with 2.5" straight through baffles, and it has always had an RSD air cleaner from that day I brought her home. I have had the bike since day one and am the only owner. Other than that the bike is an all stock 2010 FLHX, no cams, no 103 upgrade etc.
I am not a "racer", but merely did the mods to improve on sound and get rid of the heat on my right thigh. So I am not looking to tune it to the degree of shaving an extra 10th of a second off my 1/4 mile if that makes sense.
I just ordered my SEPST so that I can tune the bike for the mods. I am looking for a good base map to start from for auto tune. I don't have the software yet but I doubt they have a canned base map to start from but I am sure many people have done these very basic mods.
Thanks in advance for any constructive help and input!
#2999
The software is now a download for the latest SEPST (pro) & SESPT (street)
http://prosupertuner.harley-davidson...uperTuner.aspx Pro password/ vci# can be 1111111111111
http://streetperformancetuner.harley...reetTuner.aspx Street tuner
attached is the latest calibrations I have.
right click on it and then save-as, then remove .doc at the end of the file name in order to open as a PDF file
CHUDDLESTON (01-02-2020)
#3000
