SEPro/SEStreet Tuner Information Thread
  #3131
Old 07-26-2015, 06:14 PM
SSmike1's Avatar
SSmike1
SSmike1 is offline
Default 2014 SEPRT maps?
Can i buy maps for my bike?
I have a 2014 Limited with SAMSON strait pipes on it.
i bought the SEPRT, and loaded the Stage 1 map with SE exhaust & SE air.
Then i did 5 Runs with VCi recording, and bike runs ok,
except at slow speeds, about 30MPH, the Bike surges.
it surges at 25mph through 35mph, while i am at 5% throttle or less.
how do i fix that?
thx
mike
  #3132
Old 07-26-2015, 06:33 PM
96CubicPair's Avatar
96CubicPair
96CubicPair is offline
Default update
Russ,
I thought you were talking about the Update when you open up the program on the computer.
Its quite a system huh ?
  #3133
Old 07-27-2015, 10:00 AM
96CubicPair
Default VE Tables
On average how close are the front and rear cylinder VE tables on 96B engines? After a smart tune mine are quite different.
  #3134
Old 07-27-2015, 11:29 AM
Russ LaRose's Avatar
Russ LaRose
Russ LaRose is offline
Default ACR enabling
I have finally figured out how this system works, which is not well covered in the tutorials. The VCI update does indeed erase all on the VCI, but when the VCI is connected to the bike and computer, the first thing that happens is the existing ECM map and calibration in the bike is downloaded and stored into the VCI, so nothing is lost. Then one can play with any modifications one wishes or record any test rides and review them and either apply them to modify the existing calibrations or not as one decides. On my bike all I wanted to do is enable the ACR, which was shown as DISABLED when I opened the existing calibration data. In the left pane I clicked the + before Tuning Setup, then double clicked Working in the list below Tuning Setup, which opened the setup window in the right pane, then clicked the ACR tab which opened up the choice to enable or disable the ACR. After clicking ACR Enable, then in the lower left window where the description of the Calibration is displayed, I changed DISABLED to ENABLED, then clicked the Save tab at the upper right, then went to the REFLASH tab up above and reflashed to the bike. So far the bike seems to start easier but it may be because the battery is fully charged. From other posts, there should be audible clicks from the ACR solenoids when the ignition is turned on which I do not hear. I'll keep working on it.
  #3135
Old 07-28-2015, 07:10 AM
Sam D.'s Avatar
Sam D.
Sam D. is offline
There will remain a difference between the Front & Rear VE tables as depicted in the original tables,,, the rear cells can be 4-10 points higher.
  #3136
Old 07-31-2015, 06:15 PM
Jdharley78's Avatar
Jdharley78
Jdharley78 is offline
Default Smart tuner question
After I do my test run and download my data and then open up my map I click on front ve cylinder and open up my working table then I go back over to the tree and open the smart tune table in another box then I load my new data and generate it and then interpolate it and then update. When I do this I notice the changes in my working table and then I do a save as or a save. I've tried both and I get the same outcome. After I save the working numbers change however they don't change to the full amount like say my block said 85.3 and then after the update it changes to 80.4 but when I save it either way "save as or just save" it changes to 81.6 or something. All of my updated numbers do this for the front and back ve cylinders Is this normal?
  #3137
Old 07-31-2015, 07:27 PM
Donk kinney's Avatar
Donk kinney
Donk kinney is offline
Stage IV
Thanks I'm slowly working it out did you decrease the numbers or add to the numbers The little box on the left-hand side of the screen says The greater number decreases fuel the higher number increases
  #3138
Old 07-31-2015, 07:41 PM
Jdharley78's Avatar
Jdharley78
I didn't do either. I updated it and it automatically does it for you. However when u save it the numbers change again
  #3139
Old 07-31-2015, 11:15 PM
96CubicPair
Default VE Difference
thanks Sam... I noticed the difference and thought WTF
  #3140
Old 08-03-2015, 08:50 PM
98acrsilver's Avatar
98acrsilver
98acrsilver is offline
for all the people that still think after-run popping is still allways lean, proves why you need a afr gauge.
Quick Reply: SEPro/SEStreet Tuner Information Thread
