SEPro/SEStreet Tuner Information Thread
Old 04-08-2016, 11:17 AM
98acrsilver's Avatar
98acrsilver
98acrsilver is offline
yea ill just wait till dealer has 20% off sale
  #3222
Old 04-18-2016, 07:22 PM
kansei's Avatar
kansei
kansei is offline
SEPST was used to tune my bike by original owner and its running great . But now that I have the tuner I want to do a few smart tune runs to see if I can get the ever elusive better . The VCI shows that it needs to be updated when I plug into bike . I know that VCI will lose stored map when updated - but with I still be able to retrieve the map in the bike ? I want to save what is working well as a safety net . Bike currently has 241db001 map but I dont know how much has been done to the map .
  #3223
Old 04-20-2016, 06:56 PM
sg120r's Avatar
sg120r
sg120r is offline
With bike plugged in and turned on, go to tuning and click on the VCI tab instead of the stored calibration, that will let you pull the tune from the VCI. Then you save that on the PC. Save it as something like ORIGINAL tune.
kansei (04-20-2016)
  #3224
Old 04-20-2016, 07:14 PM
kansei's Avatar
kansei
kansei is offline
Thanks - I wasn't sure if that would pull the map back from ECM of bike after updating the VCI .
  #3225
Old 04-20-2016, 07:38 PM
sg120r's Avatar
sg120r
sg120r is offline
It will pull the current tune file from the bike, even though you do not have it on a pc. Hope that is what you wanted.
  #3226
Old 04-20-2016, 09:47 PM
kansei's Avatar
kansei
kansei is offline
Perfect - that what I what i needed
  #3227
Old 04-25-2016, 03:09 PM
joee's Avatar
joee
joee is offline
Default hd supper tunner
can someone tell me what map I could start with
I have a 06 road king 1550 kit with 203 cams and 8 degree injectors
all the ones I can find does not seam to run very good
thanks
  #3228
Old 05-04-2016, 06:54 PM
98acrsilver
check the chart. dunno what 8 degree injectors you speak of but you should be using your stock ones
  #3229
Old 05-04-2016, 07:05 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
those 8° injectors should have been replaced a long time ago under a service bulletin for 25° injectors. That might be part of your problem. Call your local dealer to find out about the swap.
service bulletin is here for your printing and taking to dealer pleasure
CHUDDLESTON (01-03-2020)
  #3230
Old 05-05-2016, 10:31 AM
98acrsilver
guess thats why i never heard of such, cause everyone shouldve gotten rid of them. that must really be an old design shows they only have 3 spray holes in them no one does that ha
Quick Reply: SEPro/SEStreet Tuner Information Thread
