SEPro/SEStreet Tuner Information Thread
#3372
Here is the description for the stage 1 map for the 2017 FLHR in the Super Tuner software :
723SHT211.dt0
Application: 2017 Touring
Configuration: Milwaukee-Eight™ 107 Stage 1
Components:
- SE Air Cleaner
- SE Exhaust
I just let the update go through, no changes to functionality, all tables still fully editable just like before. So no, they haven't neutered the pro super tuner.
723SHT211.dt0
Components:
- SE Air Cleaner
- SE Exhaust
#3373
#3375
#3376
thanks... never did pull the trigger on it anyway. This is more like what I'm looking for. I haven't been computer shopping in ages... sheesus things have changed!
https://www.amazon.com/NuVision-Touc...+with+usb+port
Good luck!
blackscootersociety (03-29-2017)
#3377
So, I have the SE Pro tuner. I am in the process of installing a set of Andrews 57H cams which will be advanced 4 degrees. I was told this gives it close to the SE 204 cam profile, but with more lift. I am looking at maps in the tuner so I can load something into it before I can get it tuned on the dyno. The map for the 204's and some of the others say ACR disabled. Is there any reason why I would leave it disabled? I would imagine the new cam profile would not make starting the bike easier and hence not needing them. Any direction on this would be great. And, if anyone has a base map that will work for my 2012 street glide with these cams set to 4 degrees advance, SE air cleaner kit, Rinehart slip ons with the bigger baffles and the gutted cat, I am all ears.
