Power Vision Information Thread
Great write up. I think the PV is going to mature into an outstanding product. I agree with you that there is nothing wrong with the PC V and auto tune for most people. The PV and other ECU flash units are a great option for those who have the time and gumption to dig into the ECU tables and self tune a number of tables the PC V can't get access to.
The reason I switched over to the PC-V was due to the lack of a competent tuner in Houston. Seems everyone can tune with a PC but break out a SuperTuner or TTS and bring up the subject of timing and they all scatter. I can pretty much guarantee there are no tuners in Houston that can tune my bike with a PV at this time. While I trust the maps from Jamie, they are not built for my bike even though I'm running nearly all of his products. Without a custom tune, I'll always be short on numbers and fuel economy.
While I think the PC-V with Autotune has been terrific....it does have hiccups from time to time.
The new T'Max for TBW bikes seems to be a good device, but the version for non-TBW bikes had too many issues for me to have moved to it several years ago or even now. One deficiency on the older version was that it didn't have knock-sensing and many were having problems with getting the spark-advance set right. It also didn't make full use of the stock MAP sensor. Although this apparently has been changed in the new TBW version I don't know if it has been retrofitted to the older version. Anyway, it costs much more and doesn't have a display unit. It does auto-tune with WB O2 sensors, but I'll get a close facsimile of that when DJ gets their software finished for use with the AT-100, which I have still installed on my bike.
I believe DJ will enhance the functionality of PV in the ensuing months with diagnostic software, etc. I know they're currently working on this for use with the AT-100 (Auto-Tune), although there is no ability to do true auto-tuning with WB O2 sensors. The upcoming diagnostic app will be fine for most of us, I'm sure.
No, it doesn't. I only needs to be mounted if you want to flash a tune to the ECU, datalog, or see the display while riding. I like the info you have at a glance, like head temperature, so I will keep mine mounted to the handlebars. As for clutter, that's subjective, but I understand your concern. That occurred to me too, but I don't think it looks too cluttered with the PV on the right and Zumo on the left. I'll take a photo of the two together and post it soon. The Zumo uses a Ram mount and the PV a Techmount, which doesn't look like I gave a lot of thought to cosmetic coordination, but I'm more interested in the functionality, as my ride isn't a show-bike anyway. You don't see the mounts unless you peer around anyway, and both are mostly black and don't grab for your attention.
Great write up! The LCD touchscreen looks slick. Thanks for sharing your approach to the added changes in step 2a+. I use to use a piggy back tuner and now SEPST and love the way you can look into the aspects of the map itself and adjust as needed. I've learned alot.
Keep us posted on how it turns out!
