Power Vision Information Thread
#7201
Whenever you change the calibration, whether from an autotune session or manual change you need to reset the offsets so the next session will make new changes.
The idea is to tune till the offsets are minimal so the ECM doesn't need to make big changes constantly in an attempt to get to and maintain targets.
Bob
Bob
#7202
#7204
#7205
Autotune remains on until you turn off autotune mode. I believe it is suggested to do multiple short runs vs one long run. The specific log data i think you need to save the log before killing power to the bike, then start another log on next run. when i log, i stop engine > save log > switch off power.
#7206
#7207
I save them to my desktop then also save them on a thumb drive. When I'm done with that bike all tunes will be on the thumb drive and I can then delete them from the desktop.
#7208
All the tunes you've edited/renamed should be there. Use the GET TUNE function in WinPV to download files from the PV to your computer. Autotune files will only have a # Untill you rename it. The Get Tune button also has a delete file on PV option to clean out the slots if thats what you want. I just overwrite them with newest version.
#7209
I'll try it again next time I go out. But I'm pretty sure you don't lose your logged data if you forget and cut power before saving.
#7210
Question for y'all. I have a 14 Street Bob and recently installed a SE Heavy Breather and some thunderheader pipes... Today I installed my power vision and loaded a map suggested to me by Roy from PV (12D103002405, SE AC w/ VH 2into1).
The bike started up just fine and sounded amazing, however there was light smoke coming from the engine about 30 seconds into idle and continued. It was difficult to pinpoint exactly where it was coming from but it seemed like it was the header/engine connection area.
Has anyone else experienced this? Is it normal? Did I do something wrong? Let me know! I'm dying to take her out on the road with her new gear. Thanks!
