Power Vision Information Thread
#8071
My current issue is since I installed the TT in my Street Glide my cold start idle gets up to between 1500 and 1600 rpm, seems high. It does eventually come down to normal after the engine warms up. It's higher than before the TT. Before TT I had PV/AT for a couple years.
The Deuce with TT does not have the same issue.
#8072
#8073
#8074
#8076
I probably need to contact Dynojet but was wondering if anyone else has hit my problems The software wont install on my win 10 laptop? It just says the wizard finished prematurely! Ahem. Tried on the wifes win 8 laptop and the software has installed but i'm not getting the update options or anything like the quick start up guide says???? Reluctant to plug the PV in incase I "brick" it ? Anyone else had this problem?
#8077
Maybe you have some Privacy/security settings, Or firewall blocking install.
The PV has to be plugged in to the computer to run update client.
http://www.dynojet.com/powervision/p...Power%20Vision
http://www.fuelmotousa.com/p-28398-d...ision.html#fm6
#8078
Sometimes AV software can block installation of drivers so be sure and disable AV software before plugging in the PV. Then re-enable the AV software after it's completed.
#8079
anyway- try over in the technical forum area on engine / clutch / mechanical related issues. this is not the right forum thread.
