Last edit by: IB Advertising
Harley Diagnostic Codes
http://www.hdforums.com/forum/igniti...tic-codes.html
Issue:
Road King is having issues and user has trouble finding diagnostic codes, so he decides to put together a list of common codes that are not easily findable.
Read below for full discussion…
Issue:
well that makes 2 or more of us heat shut down
A freind who works on Harley-Davidson and does customer work as well as team member for drag specialtys said it could be coil ignition sensor or believe it or not throttle body sensors I had an HD coil put on 2 tanks ago same problems hot won't run no throttle spits and back fires and had no throttle response when hot cool idols fine good accelerates hot s.o.l hoping got bad coil although codes for cam sensor and ignition sensors show up same
98 ultra. classic codes anyone help me out bike shuts off when hot spits and sputters
The original poster said there is nothing wrong......
"After all the diagnostic codes are displayed, the speedometer's pulses per unit (PPU) setting is displayed. This number will vary depending on speedometer part number.
SPEEDOMETER TROUBLE CODES
CODE - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - peedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit"
also "CLR means clear.
Again, not my answer, copied from elsewhere a while back as a reference.
d03 - not used
d04 - not used
d07 - not used
98 ultra classic sick
I have 98 ultra classic put new coil on because of bike shutting down when bike got hot got back ran 2 tanks of fuel through now spits cuts out then looses throttle all together and shuts down after cool down bike restarts runs mile or so then gets warm shuts off again need any and all help with codes diagnostics just plain help replaced cam sensor battery ground cable and coil plugs I'm really beyond stumped HELP
check engine light
Hi, first time user I have 07 Roadking when I go to start the bike the check engine light stays on longer than normal then goes out sometimes comes back on then goes out. Today was riding Check eng. light would come on then go out a few time. The bike never ran rough or shut off. Checked codes and get ( P0562,P1353 & PN32915-07) I cleared the codes but haven't checked to see if they came back yet. any clues to what this could be and help.
Thank
JiffyJeff
Thank
JiffyJeff
Does anyone have any idea why my 2009 fat-bob wold not have any voltage to the fuel pump/coil fuse ? i have power to all other fuses & the fuse is good.fuel pump wont come on & no spark from coil, but i have power to them & the fuel pump works with a jump wire from the battery, help i've been working on this for 3 weeks, even my local auth. H.D. shop could'nt figure it out...
Thank
JiffyJeff
Thank
JiffyJeff
PO562 IS "BATTERY LOW VOLTAGE"
P1353 IS " FRONT CYLINDER NO COMBUSTION"
Our 06 FLSTC/I just started up with the same P0562 code recently. After
a few rides, after around 40 miles, no only does the engine light continue to come on for a few seconds and go off, but after 40-60 miles of riding and using turn signals frequently, the red battery light will illuminate and stay on until the bike is shut down.
No clue what the PN# refers to. Best bet is to get it into the dealer to run a proper diagnostics, which is what we're going to do this week
