Last edit by: IB Advertising
Harley Diagnostic Codes
http://www.hdforums.com/forum/igniti...tic-codes.html
Issue:
Road King is having issues and user has trouble finding diagnostic codes, so he decides to put together a list of common codes that are not easily findable.
Read below for full discussion…
Issue:
#82
#83
Harley davidson vrod "vrscr" 2006
I have a VROD " VRSCR" 2006 , and the SPEEDOMETER, TACOMETER, ODOMETER AND FUEL INDICATOR NEEDLE DOESN'T WORKS
I used a multimeter and shows me continuity in the wires, even all other lights turns on, so, the only thing that I'm don't used is some kind of CODE READER or Code Master in order to check the computer ( I don't know how is to use it ) , What do you recommended ? Please help me
Last edited by biker12345; 11-14-2013 at 01:45 PM. Reason: I Miss Putting few words
#87
2013 Road King Classic
I know this is an old thread, but I'm new to ecm bikes. Changed out the stock bars and now have the check engine light on. The bike fired rite up and I rode about a half mile but came back after seeing engine light. Ran diagnostic and came up with some codes. After clearing some three stayed, P1510, P2122, and P2138. Any thoughts on a fix? I used same gauge wire and red weather tite butt splices for wiring extensions.
#88
#89
#90
Just an update if anyone is interested. Called a friend at the dealer who is a parts manager and he said that he has personally never sold a single TGS. So I pulled the wires on TGS side of the bars and found one 22 gauge pin got pushed out of the connector. Could barely see it was partially out of it. Re installed it and taped it together so tension was pushing both sides to the connector. No engine light or codes. Be careful with wires when doing bars.
