Ignition Timing
Old 04-16-2011, 01:36 PM
Green Man's Avatar
Green Man
Green Man is offline
Stage IV
Cool Ignition Timing
Ok so here's the deal , I just assembled a 100 cu in Revtech motor,and I'm trying to get this running today!Not sure about the whole timing.The gearcase gears seem to go together only one way,as the gears on the pinion shaft are keyed!So the breather and cam timing marks are lined up with pinion gear mark!Now the marks on the flywheel,this Revtech has 3 there's a straight slot type of mark and 1 dot and 2 dot's also!So what mark is actually t.d.c and when doe's t.d.c come into play?Seems I roll the motor over and the gearcase timing marks never line up when the marks on flywheel come up?? could someone explain this and how to set this up correctly!?
Old 04-16-2011, 05:55 PM
46u's Avatar
46u
46u is offline
When timing the gears in the gear case do not worry about the timing marks on the flywheels. I am guessing it is either a EVO or shovel?
Old 04-16-2011, 06:47 PM
Green Man's Avatar
Green Man
Stage IV
Ok ,This a Evo! So what about the marks on Flywheel,and when do they come into play?With the ign?
Old 04-16-2011, 07:03 PM
46u's Avatar
46u
46u is offline
Being it is not a stock Harley engine and Harley has had several different ways on there timing marks over the years I can only make a guess but easy to figure out. First I am guessing the 1 dot is TDC front cylinder and the 2 dots TDC rear cylinder. This should be EASY to check but bring it on the dot and check to see if this is so buy putting something in the cylinder like a screw driver and slowly turning the motor over and then backing it up. You should be able to tell if it is on TDC. Then the line is ignition timing mark before TDC on the front cylinder. Now depending on what ignition system you are running on what mark you use for ignition timing.
Old 04-16-2011, 09:20 PM
Green Man's Avatar
Green Man
Stage IV
Well not exactly sure what the ignition is either!It's shaped like a Hi4 but it's just all black and has only 2 small switches on it. 1 on or off and 2 on or off!
Old 04-16-2011, 09:41 PM
46u's Avatar
46u
46u is offline
Is this a new motor? If so did it come with any paper work? Did you check to see if there is any information on Custom Chromes web site?
gil57usa
Shovelhead
10-16-2016 07:33 PM
Ultrahog07
EVO
11
07-31-2014 01:06 PM
walteria13
Ironhead
22
10-05-2011 08:30 PM
Doug S
EVO
09-08-2011 07:41 PM
Quick Reply: Ignition Timing
