Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Check for intake leak with carb cleaner first, If it's got the MM injection, pull the cover off and use carb cleaner to clean air bleeds at 10 and 2 in upper part of intake. You may have a hose in fuel tank leaking also. Mine was the air bleeds in intake dirty. Cleaned them, now idles cold about 1200 and warm between 950 and 1000 rpms.
