Some help with Crank Position Sensor Pls.
Hi there. New member posting my first question.
Here in Panama, its very dificult to obtain correct answers about H-D motorcycles and my Road King 2001 its having problems with the Crank Position Sensor.
Did my research online and now I know that the bike is equiped with the Magneti Marelli computer (last year to be used for RK F/I)
Part number for Crank Position Sensor is 32798-00 or 32798-00B. Both works for RK from 2000 up to 2004.
My question is if the MM and the Delphi unit use the same connector for the CPS. I can find any kind of information online if they do or if I need to re-use my old connector with the new part.
thanks in advance for any help.
