03 Ultra - Headlight/Passing Lamps Fuse Blows When Turning Ignition On
I have an 03 Ultra and when I went out to ride this morning noticed my headlight and passing lamps out. I checked and the fuse was blown, replaced the fuse and as soon as I turn the ignition it blows again.
Removed the outer fairing, disconnected the headlight and passing lamps replaced the fuse and turned on the ignition and blew the fuse again. I've checked the fuse block and have 12v there and I don't see any spike when checking the the voltage when turning on the ignition. I believe that there is probably a short in the wire from the ignition to the fuse block
or could it be a bad relay? Any help is greatly appreciated.
Thanks, Kevin
Thanks, Kevin
