07 fatboy misfiring
Old 06-15-2011, 06:24 PM
2KSport's Avatar
2KSport
2KSport is offline
Default 07 fatboy misfiring
Hey everyone, I have a question a friend of mine has an 07 Fatboy that has started missing and backfiring thru the TB will not hardly idle but will clear some with higher rpms. Have changed plugs, checked comp,and checked cranksensor it was clean. Front cyl plug was wet rear was dry. Any help would be appreciated.
Old 06-15-2011, 06:31 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Check:
1. plugs...use factory only
2. plug wires
3. coils
4. fuel injector connection wires
5. CPK (crank position sensor)
6. air filter
7. Also is it throwing any codes.
8. Could be ECM
9. dirty fuel injector ( try some techron in the gas)
If the front cyl is misfiring there should be codes. It should be P1353
BTW..any mods on the bike?
Old 06-15-2011, 08:21 PM
2KSport's Avatar
2KSport
2KSport is offline
Thanks KBFXDLI, I have checked 1-6 on your list haven't checked for codes don't know how to pull them. The bike is stock no mods.
bngtag25
08-17-2012 08:33 AM
2KSport
Exhaust System Topics
06-15-2011 06:28 PM
BigDog1954
05-31-2010 04:02 AM
suggs
10-18-2009 09:06 AM
texfatboy
02-28-2007 10:39 AM
Quick Reply: 07 fatboy misfiring
