Key Fob Security System - Problem Trend Watch
The purpose of this topic is for awareness and to identify any trend this community may be aware of.
I have a '11 Road Glide with key fob security. One day I pulled up to the service door at my local HD shop to schedule some work. Appointment made, I walked out, got on the bike and the alarm went off, (directionals wagging.) The bike wouldn't start, the bike would not come off the security system. Tried 5 times, no luck. Put a new battery in the fob, no luck. A mechanic heard what was up while I was at the desk, took the keys, walked out, the bike started. Huh? What the...?
Thinking this sucked because now I'm faced with an intermittent failure and saying as much, another mechanic grabs the keys and fob, walks out and tries to start the bike. Won't start. Out of a total of 12 tries, it started once.
That was on a Wednesday afternoon. Between then and Saturday, this happened to 7 more bikes. This is not limited to just '11s.
Local HD shop said it only happens just outside their customer service door. Push the bike twenty feet forward and it will start. This by itself may be true but it is NOT only happening at that specific location. It has happened to me twice since then however it a slightly different way.
Approach bike, hop on and stand it up, the alarm goes off. (Oh crud.) The difference here is I turn the ignition on and the bike will start. So it failed for a brief moment however the bike would start. Since I've taken the little card with the instructions to turn the security off using the directionals to enter your pin and keep it in my wallet.
To this community. Be aware. I'm not sure if this is happening in other areas. Also, if you hear of this happening, post to this topic so we will have geographic data.
RickO
RickO
Have you tried your spare FOB to see if it works better? and like was posted above, the Antenna may not be picking up from where its located very well.
Tried both fobs. One with a new battery. Placing the fob on the seat didn't even work while at the HD shop. HD has a problem so we have a problem as well. Their quick (i would assume low level tech) reply from corporate was it's interference.
Negative. It's the design that may be susceptible to interference.
Have to agree with you but I would say they wanted to make it easier so you can just hop on without looking for the fob. I heard of issues with it and thats why I don't have one on mine
Update: After being a problem at first, (multiple failures) the security/FOB problem slowed down to a crawl. If it weren't for the fact that I/we do not have to actually do anything to un-arm, I'd blame the rum'n'cokes from the night before. Point here is, I do believe the problem is still here, but it hasn't happened as often.
