Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Anybody know what else to check on my 05 Softail with no spark? Crank sensor is good, coil is good, and bank angle sensor is good.... Even swapped out all of the above with ones from my buddy's running Softail, same year and model.... still no luck with spark. Bike cranks and cranks but no spark. Does not have a cam sensor. No DTC codes either. HELP! Looked for loose or broken wires with no luck. Bike ran fine one day, shut it off and would not start the next day- no spark. Checked for spark with plugs installed, and spare plugs in plug wires grounded to heads. All resistance and voltage readings are within spec for the coil, crank sensor, etc. Any help would greatly be appreciated!
Sounds like you could have a harness problem rather than a component problem. You replaced about everything that can control spark. All your fuses are ok?
