battery terminal side mount adapter? - Harley Davidson Forums
P
Thread Tools Search this Thread
Old 08-28-2011, 08:53 PM
BugDr's Avatar
BugDr BugDr is offline
Default battery terminal side mount adapter?
I also posted this in the Dyna forum. The summer is rapidly going and I can't find an adapter to hook my new battery up. The local shops act as if they have no clue. I decided to put a PC545 Odyssey battery in my 2009 Street Bob. Factory battery went south and the Odyssey has more cranking power than the OEM. Problem, the Odyssey has top mount terminals and the OEM was a side mount. Positive terminal has some play in the wires, so could switch to top mount on that end. The negative ground has NO play. I sent for an "L" adapter made by Odyssey from Battery Mart but it must be made for a different battery than the PC545 as it's terminal center to side distance is 3/4" and the PC545 would need a minimum of 1 1/8" to allow hook-up, 1 1/4" would be better. Anyone know of an adapter that would work, or is this going to be a self fabrication project. The Odyssey dealer - "Battery Stuff" in Grants Pass, OR acted like I was speaking a little known Swahili dialect when I asked them. I am an amateur auto mechanic and total newbie H-D mechanic here. Any help much appreciated.
Old 08-29-2011, 03:43 PM
UltraNutZ's Avatar
UltraNutZ UltraNutZ is offline
Audio Forum Moderator
P
Thread Thread Starter Forum Replies Last Post
Odyssey Battery in Houston? BigGelvis Touring Models 2 08-24-2015 06:30 PM
Battery time, need opinions on Lithium Iron? BigGelvis Audio Systems 31 08-21-2013 06:34 AM
Odyssey Battery TitoFTW Touring Models 18 11-05-2011 10:00 AM
battery terminal side mount adapter BugDr Dyna Glide Models 0 08-28-2011 06:34 PM
Replacement Battery Question karbar99 Softail Models 5 02-25-2011 08:04 AM
Tags
battery, cables, harley, mount, terminal, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
