so......powervision or pro super tuner?
Old 12-01-2011, 09:48 PM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is online now
Originally Posted by iclick
Has anyone ascertained with any measurable certainty that this "cam selector" actually works? Does anyone besides Steve Cole know how it works? Without this assurance through testing I wouldn't boldly levitate TTS to the top of the heap in functionality.
Absolutly it works. Different settings alter the kpa at idle. Don't forget about the egr tables and the ability on the 044 calibrations to control idle spark. Can you tell me how the PV records more data than the ecm puts out?
Old 12-01-2011, 10:13 PM
whittlebeast's Avatar
whittlebeast
whittlebeast is offline
PV writes a new record about every .025 sec with the last data set it saw in the last .025 sec. The widebands happen to send new data for almost every record. Depending on how many fields are being requested/tracked by the PV, the ECU updates the fields at about a rate of .250 sec / record. The PV simply just records the last reported value until the newest updated value shows up. So what you end up with 10 records at one RPM and then the next 10 records show the next reported RPM. Say 15 RPM higher than the last reported RPM.
None of this has any effect on the final tune.
Hope this helps
Beast
Old 12-03-2011, 07:02 PM
RLE's Avatar
RLE
RLE is offline
Found an hd dealer an hour away that actually favors the tts over the screamin eagle units, who woulda thought ha ha. Quoted me $425 for the tts, and $325 for 4-5 hours on the dyno. Said they get the best results with the tts over all else.
Old 07-31-2014, 02:42 PM
VTracing's Avatar
VTracing
VTracing is offline
Stage I
Default Found the best price on tuners
Not sure if anyone is interested or looks at this forum any more but I just bought a tuner and cable kit from this guy off ebay and I had it delivered to my house in three days. He included a promotional flyer in with the shipment and he has a website. www.oliscycles.com Tuners are only $349.95 and you get $15.00 off with coupon code OC15
Its the cheapest price I have found- Any one have better luck?
HDRetired
11-14-2016 09:37 AM
! rock103 !
02-20-2014 01:22 AM
harleytq
05-14-2013 10:54 PM
mjsawatzky
04-16-2011 06:08 PM
ga4boats
12-22-2010 12:31 PM
Quick Reply: so......powervision or pro super tuner?
