Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'm replacing the tin set on my 06 EFI heritage. From factory Harley uses the crimped hose clamps on the plastic flex lines that you have co cut for fuel pump removal. What do you replace them with? Also what is standard fuel pressure on these systems? Will a standard 1/2" fuel clamp work or is there something else typically used?
