b1006 and b1007 codes on 09 street glide
Old 02-03-2012, 10:00 AM
BIGVTWIN's Avatar
BIGVTWIN
BIGVTWIN is offline
Default b1006 and b1007 codes on 09 street glide
Anyone have any idea where to start on fixing these codes? Thanks in advance!
Old 02-03-2012, 01:25 PM
scotty3's Avatar
scotty3
scotty3 is offline
Battery voltage is constantly monitored by the speedometer. If the battery voltage fails to meet normal operating parameters, a DTC is set.
The speedometer monitors terminal 1 for ignition power and terminal 6 for accessory power.
• DTC B1006 is displayed when accessory line voltage is greater than 16.0V for longer than 5 seconds.
• DTC B1007 is displayed when ignition line voltage is greater than 16.0V for longer than 5 seconds.
So you need to check your voltage output as you could end up cooking your battery.
Old 02-03-2012, 01:39 PM
BIGVTWIN's Avatar
BIGVTWIN
BIGVTWIN is offline
Check battery with engine off it was 12.39 with it running it is at 14.2. Also the gauges and stereo are flashing!
Old 02-03-2012, 06:15 PM
ican's Avatar
ican
ican is offline
Default voltage
Check it at 1500/2000 rpm. Does it go above 16 volts at that rpm?
Old 02-05-2012, 12:55 PM
BIGVTWIN's Avatar
BIGVTWIN
BIGVTWIN is offline
Voltage stays at 14.6 at 2000 rpm. But it did jump up just for a .10 of a second .
lv2ride56
10-20-2013 04:37 PM
jjmil03
02-20-2012 07:38 PM
DarkManC
07-10-2009 07:24 PM
SlickT
09-18-2008 08:31 PM
WRAITH
04-24-2008 06:59 AM
Quick Reply: b1006 and b1007 codes on 09 street glide
