I effed up...
Old 08-20-2012, 01:34 PM
BLUE WAFFLE's Avatar
BLUE WAFFLE
BLUE WAFFLE is offline
5th Gear
Default I effed up...
So, I guess I'm putting this here, to see advice.
New 2012 FXDB, 2 months old, bought with 21 miles, now has 6k+.
While ago, took off stock mufflers and crossover in a misguided quest for increased fuel mileage. It worked, I'm averaging over 50mpg's, compared to the stock 43 or so. Run on 93 pump gas.
Went in today for the rectifier recall, and he test drove it to make sure it was fine, came back, pulled my plugs and brought them to me, and asked me whY I did what I did.
I said, I was told if I changed exhaust without touching intake, the ECM would be able to compensate without being too lean. Judging by the plugs, not true. Almost pure white, with slight signs of detonation. He threw in a clean pair for me.
He explained that with the new bikes coming out, the ecm is different than the older ones ( showed me the serial to show me). You can change the air filter now to a free flow type, but not the exhaust. Because of the MAF, it can compensate with the intake, but not the exhaust. He said I should either go back to stock pipes (which I Don't have) or get ANY tuner out there to feed it more fuel, or I'm going to melt my valves eventually.
He didn't try to sell me a Harley product, he threw in a new set of plugs, and he even showed me where the bin is in the back so I can "go shopping" for some stock take-off headers and mufflers in case they "come in stock".
Is this true? If so, is it PC3 time?
Old 08-20-2012, 02:15 PM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Get a Dynojet Vision or a soon to be released new model of TTS.
The days of PCIIIs are L O N G gone.
Old 08-20-2012, 04:19 PM
newmission's Avatar
newmission
newmission is offline
Yup. Dynojet Power Vision. Soon to be the most user friendly tuner out there hands down!
Old 08-21-2012, 11:06 AM
BLUE WAFFLE
5th Gear
Guess its power vision time. How much do they run?
Anyone around the Tampa area have one I could borrow? lol.
Old 08-21-2012, 12:16 PM
TickTock's Avatar
TickTock
TickTock is offline
Since you are in Tampa area call Doc's Performance in Clermont and get your bike tuned properly right off the bat. I will PM you his email
Old 08-21-2012, 02:37 PM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
So, I guess I'm putting this here, to see advice...
Your post suggests you've gotten a lot of bad advice/info.
As suggested above, ride over to Clermont and see Doc.
Old 08-21-2012, 06:59 PM
BLUE WAFFLE
5th Gear
10-4, will do on a day off.
durtyburt
06-15-2016 03:35 AM
harley#1
03-30-2013 09:11 AM
sportyscoop
08-26-2012 03:29 PM
matts Dyna
04-21-2010 01:30 PM
homerandpooh
Exhaust System Topics
12-13-2008 10:58 AM
Quick Reply: I effed up...
