Shovelhead - problem static timing new Crane Hi-4N
My old crane hi-4 apparently died and the S&S folks sent me a new hi-4N (looks a lot stouter). Got it wired up (correctly I think - I hope as I don't want to pull the tank again). Got the TDC timing mark showing in the center of the timing window.
Instructions say to static time by turning unit clockwise until the red light goes out. It never goes out. I have it set for 5 (single fire - oe - electric start) and it has VOES attached (worked before).
I'd like to know what the conclusion of this installation was as I am thinking of getting one of the new Hi-4N modules myself. I had trouble with two out of the three Hi-4's I bought and so I am leery about these units. I hope the new unit is much better but it is still so new there is not a lot of feedback form owners yet.
I have a kickstart on my bikes so I am very interested in using the Crane module.
It appears my problems with my Crane Hi-4 were self induced. I had previously removed the nose cone. When reinstalling I apparently missed by a teeth or two getting the pinion/cam/breather gears properly lined up. Once that was corrected static timing worked flawlessly and the bike never ran better once the hi-4n was installed.
Hi 4n red light still on at tdc
83 shovel fxwg, red light wont turn off when sliding module forward or backward . I know I'm at tdc. Seems my crank gear has the timing mark at the tooth point of the sprocket instead of the valley ..wtf. if I set the new cam even 1 tooth off would this cause the red light not turning off? Or any one have experience with these any suggestions? Thanks in advance ! Hah!
