Harley Davidson Forums
Harley Davidson Forums (http://www.hdforums.com/forum/)
-   Ignition/Tuner/ECM/Fuel Injection (http://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection-55/)
-   -   Correct Speedometer 96 Dyna (http://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection/813639-correct-speedometer-96-dyna.html)
jim70 10-06-2012 01:30 AM
Hi all,
I need to replace the original speedo on my 96 Superglide. It sits on a dual mount beside my factory tach. The decal on the back side reads 67249-96A..but Harley does not recognize that number and tells me the superceded number a 97025-XX??
My existing speedo is not a single plug type but has wiring going to it.
Can anybody steer me in the right direction as to what exactly the correct number should be?
And if other compatible models of that year might fit?..Sportster,etc..
Thank you
UltraNutZ 10-07-2012 12:29 PM
the correct speedo for your bike is 67025-96
96 - 98 FXD use the same speedo
