wiring ???? NOVA-MMB SPEEDO
HAVE A 2006 SWIFT PUNISHER AND HAD TO CHANGE THE WIRING HARNESS TO THE THUNDER-HEART KIT. THE SWIFT USES THE NOVA-MMB 80mm ANALOG SPEEDO WITH DIGITAL MILAGE, TRIP, ETC AND HAS THE TOUCH BUTTONS TO SELECT THE DIFFERENT MODES. ALSO HAS THE NOVA-MMB ANALOG TACH. THE PROBLEM I'M HAVING IS WIRING THE THUNDER-HEART SYSTEM TO THE NOVA'S. CAN'T SEEM TO FIND ANY Wiring DIAGRAMS FOR THE NOVA ITEMS, SO IF ANY ONE HAS THESE, ID APPRECIATE A COPY.
See another post in this section for more details.!!!!!!!!
SEND TO bherr@atlanticbb.net
thanks,
ben herr
thanks,
ben herr
a quick google search turned up this. It's the 48mm but I would assume the wiring is probably the same.
http://www.zodiac.nl/instructions/710370.pdf
wiring issue
let me add some more details to better explain. The speed is mfg by Nova-mmb, 01/06, type 3.3213/004. it has three cable custers, one has 2 wires, gray and gray/w black stripe. #2 has 3 cables, 1-red, 1-yellow & 1 black. this powders the speedo light with the red and black is ground, don't know what the yellow does. 3rd cable has 4 wires, 1-red w/white stripe, 1-black /w white stripe & 1- white. Also feeding the speedo which is analog and has a digital mileage, trip and time display are 2 cable that come from 2 touch buttons located under the triple tree and changes the select modes. these cables each have 2 wires gray and 1 black. All of this was on a 2006 Swift punisher and the stock module that controlled the starter, turn signals, brake lights went back and they are no longer available, so I ordered a MHC rewire kit from Thunder-Heart. Also located on the triple tree is a display strip with lights for the turns signals, high beam, oil pressure and neutral indicators. the cable from the strip has 8 wires:
1-brown
2-red
3-yellow
4-orange
5-blue
6-black
7-violet
8-purple
I figured out the brown and black for the turn signals, but can't seem to get the other indicators.
Now the tack has 4 wires;
1- red
2- brown /w white stripe
3- orange
4- green
Anybody that has some idea of how all these get wired would be great. I've got the high/low beam, turn signals, horn, run/stop and kill switches all working.
I can't seem to find a wiring diagram for these nova-mmb and the Zodiac wiring diagram doesn't have the same cable setup.
I could also use a wiring diagram for the Swift punisher which I haven't been able to find either, so I need help guys!!!
Thanks,
Ben Herr
1-brown
2-red
3-yellow
4-orange
5-blue
6-black
7-violet
8-purple
1- red
3- orange
4- green
Thanks,
Ben Herr
Asuperglide
26
12-20-2005 05:55 PM
