What to do when a Tuning Configuration File does not match...
Ok, so the user manual is not the best and first time user of SE Super Tuner II makes matters worse. Hooked up the tuner on this bike I purchases used and off VCI see the following
Configuration: 1550 High Output
SE air Cleaner and Breather Kit
SE 1550 Big Bore
SE High Compression Forged Pistons
SE 257 Cam
SE Performance Tuning Mufflers
I want to change the White Brothers E Series to something quieter have a set of SE slips ons and stock pipes but see no configuration or way to change just pipes?
Think I need a seasoned expert before I flash anything!
Am I missing something simple to change in the tuner tool box or something?
SE 1550 Big Bore
SE 257 Cam
Does your bike have cams and whats listed? not sure what you are asking..if the engine is built up then you will need to adjust the mixture. there are no base maps for that. If this is a used unit then I don't think that it will work on your bike. They are married to the first bike they are installed on.
Any Richmond area forum members who have experience and can help contact me. Will try to post saved/recorded run.
Location: Back in the Good Ole USA. South Carolina to be exact.
SE 1550 Big Bore
SE 257 Cam
SE 1550 Big Bore
SE 257 Cam
You can change the mufflers you can likely use the same calibration but you'll want to go through the Smart Tune process.
