No Lights...HELP!
Old 01-17-2013, 02:42 PM
bakednormals's Avatar
bakednormals
bakednormals is offline
2nd Gear
Angry No Lights...HELP!
Hey guys, wondering if anyone can point me in the right direction. I have a 2001 FLHT, bone stock, that has this problem that just developed. With the engine running, I have no headlight (both lo/hi), no running lights front or rear, and my fog lights don't come on at all. I've checked the fuses to make sure nothing was blown, even switched some fuses around. Emergency flashers work, and turn signals work as well. I also have NO lights on my dash, save for the turn signal indicator lights when I used the indicators and the speedometer. Fuel gauge, voltmeter, tachometer, nothin' works. If you fine folks on this here very fine forum can help, I'd greatly appreciate it!
Old 01-19-2013, 09:45 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
pop open your outer fairing. Fairing is where most of the lighting circuits tie together. Check the fairing brackets to see if one of them hasn't broken and rubbed through your wiring harness.
ElectraJim
Electrical/Lighting/Alarm
34
09-01-2016 07:58 PM
nthere1
05-14-2014 04:38 PM
mbauma
Audio Systems
07-24-2013 01:50 PM
joetheviking
07-27-2011 06:18 PM
Badbagger
01-02-2008 07:44 PM
Quick Reply: No Lights...HELP!
